Both my master cylinders (brake and clutch) are leaking. Instead of rebuilding them now, they seem inexpensive enough to replace. It looks as though the easiest way to replace them is to remove the entire mount including reservoir and disassemble on the bench. In order to do this, does the wiper motor have to be removed? What is the easiest way to replace the master cylinders?
