I just finished rebuilding my MC on my '76B, it went pretty well, getting it on and off was the biggest problem. Now for my trouble. I think the brake failure piston is hung up and is not allowing pressure to the rear wheels. The pedal is soft after bleeding and with the car on stands,brake pressure applied I am still able to turn the rear wheels (new shoes,cylinders and adjusted)Should that piston move freely? What position should I start it out at? After removing the large nut at the front end of the MC should that piston be seated in as far as I can get it or should I start out with it up against the distance piece? Thanks, MACK /ubbthreads/images/graemlins/cheers.gif
