bugedd
My bugeye has front disc conversion with an aftermarket Moss master, which I think is 7/8", the only thing they offer. When putting it in, I recall the push rods from the old system being too short. After reading at Gerardsgarage.com about the correct 3/4" master working better for the disc conversion, I saw that the 3/4" bore used shorter push rods. So I am thinking the master that I have sitting in the shed may be the correct one, and I should check that out and perhaps use it. So first, how do I identify it as the correct unit? And second, if it is the proper unit, who rebuilds them?
Hi Guest!
