nevets
I read somewhere that if the fluid in the master cylinder reservoir raises when the brake pedal is depressed it is an indication that the 'foot valve' seal is not working properly. When I depress the brake pedal the fluid is disturbed (sort of pulses) but I do not believe the level is raising. Is this normal? Should there be zero movement in the fluid when the brake pedal is depressed?
Thanks!
Thanks!
