Master Cylinder Clips
RonR
Folks.
I am missing one of the circular clips for the push-rod end of the master cylinders.
Does anyone have one to sell or know of a source?
Thanks.
Ron
Are you talking about the clip that goes in the end of the M/C bore that holds all the guts in? If so, I should have one, but will have to wait until I get home from work so I can dig for it.
It's also usually included in the rebuild kit.
Thanks Art,
I was able to find a clip locally.
The rebuild kits I got from The Roadster Factory did not inlcude the clips. It also appears they are the wrong kits as there is a large rubber washer in each kit which does not appear to go anywhere and the boot for the push-rod end of the master cylinder is too small.
Ron
