I have a DW AL head and steel tubular headers with exhaust pipes 1 and 4 meeting at a collector which in turn runs down to meet another collector where the pipe from siameze'd 2 & 3 join in and on to the muffler, etc. The pipe from the 1-4 collector cracked and broke rather cleanly just below the Y joint and in order to get the top section out for welding I had to remove the carbs as well as the 2-3 pipe. Everything came apart cleanly and I was able to get all of the above off without damaging the metal gasket. In some places there appears to be remnants of what was probably an Ultra Copper-type sealant applied when I installed the head and manifold almost 20 years ago.
My question is: Should i put a thin layer of Ultra-Copper or something similar on the outer face of the gasket or simply go directly to reassembly?
