nevets
OIL CHANGE
FEMALE PROCEDURE
1) Pull up to Jiffy Lube when the mileage reaches 3000 miles since the last oil change.
2) Drink a cup of coffee
3) 15 minutes later, write a check and leave with a properly maintained
vehicle.
Money spent:
Oil Change: $20.00
Coffee: $1.00
Total: $21.00
MALE PROCEDURE
1) Wait until Saturday, drive to auto parts store and buy a case of oil,
filter, kitty litter, hand cleaner and a scented tree, write a check for $50.00.
2) Stop by 7/11 and buy a case of beer, write check for $20, drive home.
3) Open a beer and drink it.
4) Jack car up. Spend 30 minutes looking for jack stands.
5) Find jack stands under kid's pedal car.
6) In frustration, open another beer and drink it.
7) Place drain pan under engine.
8) Look for 9/16 box end wrench.
9) Give up and use crescent wrench.
10) Unscrew drain plug.
11) Drop drain plug in pan of hot oil: splash hot oil on you in process.
Cuss.
12) Crawl out from under car to wipe hot oil off of face and arms. Throw
kitty litter on spilled oil.
13) Have another beer while watching oil drain.
14) Spend 30 minutes looking for oil filter wrench.
15) Give up; crawl under car and hammer a screwdriver through oil filter and
twist off.
16) Crawl out from under car with dripping oil filter splashing oil
everywhere from holes. Cleverly hide old oil filter among trash in trash can to avoid
environmental penalties. Drink a beer.
17) Install new oil filter making sure to apply a thin coat of oil to gasket
surface.
18) Dump first quart of fresh oil into engine.
19) Remember drain plug from step 11.
20) Hurry to find drain plug in drain pan.
21) Drink beer.
22) Discover that first quart of fresh oil is now on the floor. Throw kitty
litter on oil spill.
23) Get drain plug back in with only a minor spill. Drink beer.
24) Crawl under car getting kitty litter into eyes. Wipe eyes with oily rag
used to clean drain plug. Slip with stupid crescent wrench tightening drain
plug and bang knuckles on frame removing any excess skin between knuckles and
frame.
25) Begin cussing fit.
26) Throw stupid crescent wrench.
27) Cuss for additional 5 minutes because wrench hit bowling trophy.
28) Beer.
29) Clean up hands and bandage as required to stop blood flow.
30) Beer.
31) Dump in five fresh quarts of oil.
32) Beer.
33) Lower car from jack stands.
34) Move car back to apply more kitty litter to fresh oil spilled during any
missed steps.
35) Beer.
36) Test drive car.
37) Get pulled over: arrested for driving under the influence.
38) Car gets impounded.
39) Call loving wife, make bail.
40) 12 hours later, get car from impound yard.
Money spent:
Parts: $50.00
DUI: $2500.00
Impound fee: $75.00
Bail: $1500.00
Beer: $20.00
Total: $4,145.00
ATM
MALE PROCEDURE
1. Drive up to the cash machine.
2. Put down your car window.
3. Insert card into machine and enter PIN.
4. Enter amount of cash required and withdraw.
5. Retrieve card, cash and receipt.
6. Put window up.
7. Drive off.
FEMALE PROCEDURE
1. Drive up to cash machine.
2. Reverse and back up the required amount to align car window with the machine.
3. Set parking brake, put the window down.
4. Find handbag, remove all contents on to passenger seat to locate card.
5. Tell person on cell phone you will call them back and hang up.
6. Attempt to insert card into machine.
7. Open car door to allow easier access to machine due to its excessive distance from the car.
8. Insert card.
9. Re-insert card the right way.
10. Dig through handbag to find diary with your PIN written on the inside back page.
11. Enter PIN.
12. Press cancel and re-enter correct PIN.
13. Enter amount of cash required.
14. Check makeup in rear view mirror.
15. Retrieve cash and receipt.
16. Empty handbag again to locate wallet and place cash inside.
17. Write debit amount in check register and place receipt in back of checkbook.
18. Re-check makeup.
19. Drive forward 2 feet.
20. Reverse back to cash machine.
21. Retrieve card.
22. Re-empty hand bag, locate card holder, and place card into the slot provided!
23. Give dirty look to irate male driver waiting behind you.
24. Restart stalled engine and pull off.
25. Redial person on cell phone.
26. Drive for 2 to 3 miles.
27. Release Parking Brake.
FEMALE PROCEDURE
vehicle.
Money spent:
Oil Change: $20.00
Coffee: $1.00
Total: $21.00
MALE PROCEDURE
Cuss.
twist off.
surface.
21) Drink beer.
frame.
28) Beer.
30) Beer.
32) Beer.
missed steps.
35) Beer.
36) Test drive car.
Money spent:
Parts: $50.00
DUI: $2500.00
Impound fee: $75.00
Bail: $1500.00
Beer: $20.00
Total: $4,145.00
ATM
MALE PROCEDURE
6. Put window up.
7. Drive off.
FEMALE PROCEDURE
8. Insert card.
11. Enter PIN.
21. Retrieve card.
