Hello all , I have hit a snag with my rebuild on a 1980 TR7 convert . I should say another snag as this has been a five year project . I purchased the car for $400.00 from a guy who had it on jack stands in his garage . It was not running and missing a wire harness for the engine . The last time it was registered was 2001 , after rebuilding the original engine only to have a blown head I decided on a v6 conversion . I did the Johns cars conversion and was a good bolt on kit . So after rebuilding the 1978 Buick 231 bored 30 over , medium cam , headers I dropped it in. The car fired right up and purred like a kitten , give or take a few decibels . I finally got my new drive shaft , so I installed it replaced the brakes , and was ready to set it back on the ground . Checked one last time for fire up and nothing ... no power to anything inside the car . I've got power to the starter , alternator , and that's about it . I tried a suggestion of jumping a battery to the cig lighter and the headlights pop up and my clock worked . I have tried to jump off the small wire on the starter right to the battery and the lights will activate but only if the key is turned to start . So all I did from having a running car to a no power issue was brakes and driveshaft . I was wondering about starter relay , or ignition switch but then I think my clock would not be wired thru these so I still sit here wondering what o look at next . Anyone have any ideas ? I just pulled the dash back out of it and will recheck for loose or broken ground wires but help would be appreciated . Thanks in advance . Rick
