MGTF1250Dave
Aloha All,
Last week, going home from work an infrequent rain fall called for the windscreen wipers. It wasn't heavy, no need to put the top up, but the wipers won't work. Fortunately, the TF has wiper parking knobs in the dash, so I could manually move the wiper blades to clear the windsheild. Over the weekend, I worked on fixing the wipers. I checked the connections, switch and power to the motor and all was fine, so I pulled the motor to check it. The grease in the drive mechanism was dried out and caked and the brushes and commutator of the motor were grimmy. I cleaned the motor, regreased the drive and now everything works fine. This 50 year old motor now works fine and looks as good as new and I didn't have to spend abou $300 to replace it. I think I cleaned the motor about 20 years ago. I know as LBC owners, we occassionally like to pick on Lucas for inventing darkness, but many of his parts work well and can be repaired when necessary. As LBC owners, I think we reserve the right to coment on Lucas, but if you don't have a LBC you should keep quiet. This weekend I was pleased with the durability of this Lucas motor.
Safety Fast,
Dave
Safety Fast,
Dave
Hi Guest!
