LoneRanger
Member
Another electrical issue-here is the sequence of events-Thanks for listening. '75 TR6-rear tail lights and dash lights go out one night on a rare evening drive-find blown fuse. Easy fix right?? Replaced fuse with Rimmer 35A. During testing, the original clear hooters rocker switch craps out, Fuse blows again, no headlights. While pulling the switch out, find 2 wires fused together, insulation torn away or separated, bare wires exposed and clearly connected. Some slight melting on the plastic casing of the switch. Put new fuse in and seemed fine, trying to rule out a short somewhere else. I have the wiring diagram from active, but I am not an electrician.
My questions to the experts are, will a new clear hooters rocker switch solve my problem or is this just the beginning of re-wiring the whole car??
What could cause the wires to fuse together and when did that occur??
Lastly, is the car safe to drive during daylight hours, until I get the switch??
Thanks again for listening, appreciate the help.
