Lucas rebuilder
jlaird
Provided by a rebuilder of Lucas generators and starters, https://www.starautoelectric.com this site may be of intrest. I have an email out looking for a armature.
Instruction on how to polarize a Generator:
In all the years I have been in business, I have heard many versions on how to polarize a generator and voltage regulator. Some versions are correct, others are totally wrong.
Polarization is a procedure which matches the polarity for the generator and the voltage regulator. The majority of the vehicles are manufactured negative ground although some of the older vehicles were manufactured positive ground. The generator has to be set up for either polarity. The generator will charge either way, however the voltage regulator has only one polarity. Whenever the battery is disconnected from the vehicle for any reason the polarization procedure should be performed.
The recommendation on how to polarize a charging system is the following: After the installation of a battery, generator or voltage regulator follow these procedures. The terminals on the voltage regulator are labeled with letters and this is where you will do the polarizing procedure. Both of the components will have battery power so do not start the vehicle or turn on the ignition switch before polarizing them. You will need a small piece of wire fourteen or sixteen gauge with alligator clips on the ends. Find the "B" terminal on the regulator and attach one of the alligator clips, find the "D" terminal and touch the terminal with the other alligator clip. You can touch the terminals a few times and it will produce a soft light spark. Under no circumstances touch the "F" terminal or any other part of the regulator or you could damage the regulator.
Start the vehicle and you should see the red generator light go off on the instrument panel, you may have to rev the engine up a few RPM, generators have a tendency not to charge at idle speed. If you have a gauge on the instrument panel the gauge will respond accordingly.
Look for more technical information in the future on these page.
Sincerely,
Mike Martinez
Here is answer from them. Total rebuild is $ 194 about the same as Moss $190 new one. Armature is $114. Seems like the way to go is a rebuild for $195 as that includes new fields, armature, burshs, bearings, testing, and such.
Mr. Laird,
According to our catalog application your generator is equipped with a rear tach drive hook up on the commutator end plate. The generator number is Lucas part # 22744. If this the armature that you are inquiring about, we currently have rewound armatures in stock. The cost of the armature is $114.79 exchange. There would be a $50.00 refundable core charge added. Also shipping charges would be extra and sales tax would be added if you residue in California.
The armature is available for immediate shipping and usually ship by United Parcel Service.
Best Regards,
Mike Martinez
Star Auto Electric Company
What is what doing in a car. The generator is on my work bench and the body is about 6 hours away. ????????
To drive the Tac of course and keep the battery up.
No but I think a couple of aspirn are in order.
