Lucas Horn
Whitephrog
I have a non-Bugeye NOS Lucas horn that I had intended to use on a BE but have changed my mind. The horn has the following markings: H6, 12V, 70159, 5-63. The Lucas p/n appears to be 54068033. Do any of you know what car this horn goes on?
After th' BOB shows and I've started onna second pot I'll check the MGB here...'bout another half-hour or so. The last set of numbers is just what it appears to be: date of mfg. It 'sounds' as if it was for a positive earth BMC 'everything' of the era.
EDIT: BUM info above! On examination, the horns here on my '64 MGB are: "LUCAS 9H ENGLAND" on the underside of each, with "60145A, 4-64" and "60122E, 3-64" showing on top. No voltage specified. And the horns are not polarity specific. Grounding at the horn push completes the circuit.
