angelfj1
We have been having a ball driving the Grey Lady and put about 1000 miles on the clock. However, as of this past weekend, we have now had four condensers fail. Here's an account of the first failure which prevented us from enjoying the breakfast run at the TRA meet in North Carolina.
<span style="font-weight: bold">Duryea Day - Boyertown, PA Saturday - September 1, 2012</span>
<span style="font-style: italic">"TRA has a long tradition of conducting a breakfast run on Saturday morning of the meet. We were running the car up the mountain roads to the show field on Friday and noticed a misfire. We only had 25 miles on the car before we left for the show, and we had not yet established any history on the carburetor or ignition tuning. After the show, the car ran great for about ten minutes and then the miss came back. After inspecting the float bowls and swapping distributor caps, rotors, and wires, to no avail, we watched the breakfast run depart past us and our spirits sank. Reasoning that the condenser was the next logical substitution, we dove into our “spares department” tote bin and brought the car back to life with the next push of the starter switch."</span>
After returning home we have experienced three more condenser failures. The circumstances seem to be consistent. Start out, engine cold, runs great, smooth idle. Engine warms up, approx. 180F still OK. Get into a bit of traffic, usually stop light and as engine approaches approx. 2/3 full scale on the temp gauge, the engine begins to stumble. If I try to accelerate, the engines misfires and at times will backfire. After these incidents I have pulled off the road and gone for a coffee whilst the engine cools down. If the temp goes below half scale, about 180F the engine will start up and run nicely. Upon heating up a little the cycle repeats.
We have conducted all of the usual checks and have ruled out timing and carb settings. Colour Tune looks ideal. The plugs are a bit sooty and we have considered going to the next highest heat range. But when we replace the condenser with a new one, the engine runs well regardless of temp. This fix does not last long though and eventually the condenser completely craps out, usually a few days later.. Considering that condensers are most difficult to test, we have reached this conclusion based on a process of elimination. At least one time a new condenser did not cure the problem and we could only conclude that it was dead out of the (green and white) box.
So, perhaps you can offer your experience and suggestions. I hear that better condensers are available. Does anyone know of a source?
Except for poor quality, is there anything else that may be causing these condensers to fail?
Cheers,
Frank
Cheers,
Frank
