Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
I think I mentioned this before. Once the car is lowered, check the full upward travel of the shock arms. You might want to use the shorter shock links from an older car to prevent bottoming out of the shocks. Could be costly later. JMHO. PJ
keep the bar... interesting that your 76 has bars... my 76 had no bars when I got it. I added a front bar when I lowered my car. I have an aftermarket rear bar waiting to be installed.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]I think I mentioned this before. Once the car is lowered, check the full upward travel of the shock arms. You might want to use the shorter shock links from an older car to prevent bottoming out of the shocks. Could be costly later. JMHO. PJ [/QUOTE]
I would.
