Can anyone offer assistance to help to determine the cause of my right side turn signals?
At first the right side turn signal didn't work at all. I replaced the flasher unit and when I put the right side turn signal on the flasher unit got so hot it burned up. Thinking there was a short somewhere in the turn signal switch I opened up the trafficator unit and made sure the wireing harness were not crossed and I did some adjustments then replaced the flasher unit again and now they work but the bulbs are so low they are barely visable and the blinking is very slow. I checked the wireing to the individual signals and everything seems to be fine, any suggestions thanks
The left side works fine, bright bulbs ahd moderate blinking speed.
Hi Guest!
