Lotus 11 Alpha
tiga2
Hey,
I am at last scanning some of my old slides from the 60's. This was taken at Del Mar, CA about '64. My good friend John Mcknight still has this car, a Lotus 11 with an Alpha motor and Corvette box. He only ran it a few times, pretty scary with those skinny tires and wheels! /ubbthreads/images/graemlins/driving.gif
That's interesting. IIRC Alfas were 1300 and 1600cc at the time. Which one is in his Eleven?
THAT should make for a fun ride!! Full chat should sound like a mad hornet!
Note the Jaguar MKIX in the background. I used to tow my MG to the track with one of those , throw everything unnecessary out and race them both.
Alan T
Neat picture! That Eleven must have flown with the Alfa motor.
Re: Lotus 11 Alfa
Yea, that was his dad's, and John still has that, along with a blown MGTC and all kinds of good stuff. /ubbthreads/images/graemlins/driving.gif
Re: Lotus 11 Alfa
You can bore and sleeve and alfa Liner?
Re: Lotus 11 Alfa
Seems a bit of a job. I'd be curious as to the how/why of it myself. It had to have been an expensive proposition for a 50cc per hole increase. Pistons would have to be either sourced by size (and wrist pin fit, diameters etc. all metric), or made specifically for it.
I'm pretty sure I've both a 1300 and a 1600 here in bits. I may do some measuring out of idle curiosity... when I get time.
Re: Lotus 11 Alfa
Almost had to be (stroked) IMO to get to 1500. The liners are kinda "close" together in there. 78mm bore on the 1600 (1570cc), with a stroke of 82mm... both the 750 and 101 series 1300's (1290cc) were a bore of 74mm with a ~slight~ oversquare 75mm stroke. Curiously, the GTA Jr. (1290cc "twin-plug") was at a 78mm bore (1600 liners?!) and a *short* 67.5mm stroke.
Re: Lotus 11 Alfa
[ QUOTE ]
Almost had to be (stroked) IMO to get to 1500. ...
[/ QUOTE ]
Either that or bored almost 6mm oversize. Do the liner walls have 3mm in them? That's quite a bit.
ISTR that these engines could be stroked but needed to have notches cut in the liner bottoms (& block?) but may be wrong about that one.
Also curious about the Corvette transmission. The close ratio Chevy 4 spd had a 2.20 first gear and may not have been the best fit for an Alfa. I wonder why they didn't just use the Alfa box although the shift lever would have needed major shortening and maybe even some sort of remote.
Tiga2 - do you know?
Re: Lotus 11 Alfa
I think 3mm would be making the liners a little on the thin side. Mebbe cut thinner and then sleeved? That doesn't seem to make sense tho... The 1600 block had a redesign to allow a longer stroke. IIRC the 101 series 1300's were close, but the 750 series would interfere and need the rod cutouts. This is getting into the minutiae a bit! /ubbthreads/images/graemlins/grin.gif
Maybe someone could 'volunteer' a GTA or that Eleven for us to 'inspect' some of this? /ubbthreads/images/graemlins/devilgrin.gif
Re: Lotus 11 Alfa
There was an unfinished Westfield 11 / Alfa in Maine for sale a few years back.
It would have been super cool
Re: Lotus 11 Alfa
Coldplugs, did you ever run across a fellow in Wiscasset named David Laemmle? He did some work on my XK-120 back in the early '70's and I remember him having an Alfa 1500 from the 20's and a Maserati 200SS birdcage looking sports racer too, 4 cylinders, 2 overhead cams and 2 honking great Webers! I remember one afternoon slapping some dealer plates on the Maser and flying down the road to "blow out the carbon". His shop was called Carriage Motors IIRC.
Re: Lotus 11 Alfa
Michael, no I don't know him. We get over to Wiscasset occasionally and I'll make a note to stop in to see him if he's still there, probably after Christmas. Sounds like a interesting guy.
I'll let you know if he's still there.
