Loosen those nuts!
NutmegCT
Something I just discovered online. Using a lighter and a candle to remove a tight nut.
I've used heat to "expand" and loosen a nut before, but never thought of melting wax into the threads. Heat rises, wax drips.
I wonder if the heat alone is enough to loosen the nut. Is the wax merely a "placebo"?
Wish I'd looked at this before I broke the end off my hand brake cable. Tom
but what do you do when the wheel stud is spinning?
