rustbucket
I am working on a friend's 70 MGB w/ wire wheels. He has been complaining that the front end seemed a little loose, especially over bumps.
I had already replaced the shocks, and replaced all the suspension bushings with urethane pieces. The kingpins seem to be in decent shape.
With the front wheels in the air, I grabbed one of the front wheels and moved it to check for play in the wheel bearings. I felt a lot of play in the wheel. On closer inspection, I noticed that the spokes seem loose and the movement is the rim moving in relation to the hub.
Can the spokes be tightened? Should this be attempted? On some of the spokes, that are loose, the nipple appears to be run all the way in, so no thread shows on the spoke.
Any advice would be appreciated.
