Looking for hs4 aud 135r carbs
scotmont
Member
I'm the new guy with the 69' mgb gt.
It's been suggested to me that I get the 67' carb set up for my 69'. It's a lengthy (and thorough) explanation that I won't get into now. If people are interested in seeing it all I can post it. It's quite informative.
Does anyone have experience with these carbs? Where should I go about getting set up with them. I see them listed for sale as new for $800.
You all have been very helpful so far. Thank you.
scot
Scot, I may have a parts car in a few weeks. Its a 65-67. If you have not found any in a few weeks PM and I will let you know if my offer was accepted on the parts car. Bob
Scot, There is a set on ebay that I think you may be inquiring about. Rebuilt and proper rebuilt is 2 totally different price ranges. Ask about throttle shaft replacement and new shaft bushings. Anyone can clean them and put kits in. Having nice tight throttles shafts is priceless! Bob
Scot, I would be interested in reading about the differences in the hs4 carbs and if you would post your info on them I would be eternally greatful.I have been putting up with my hif4's since I got my 74 and wishing I could come across a set also.I didn't realize that there was much difference in them between the years.I would like to get a set that needs to be rebuilt and do it myself but that's just me :crazy:.
I was wondering if the linkages are the same between the hif's and the hs's also, because I have seen some pairs without linkages and was wondering if they would interchange.
Good luck in your search. :cheers: Mark
Mark, The linkage is different on the HIF and HS series carbs. I have quite a few spare sets of linkage for the HS carbs if you buy a set without them. Bob
Thanks for the possible connects on the carbs. My car is at "Johns Jaguar" here in SF. I like him so far. I will know more this week what I'll be doing about the carbs.
Here is the blurb from Marty with the MGOC.
"the ideal thing is to have your engine at '67 specs, that is, the only smog equipment being a PCV valve, which actually helps the engine to run better. I suggest doing this, but you probably just want to keep the old smog equipment just in case the government goes back on their word in the future. there is kind of the quick way to do this and then the proper way. the cylinder head and intake manifold are both different, as are the carbs, so the quick way would avoid dealing with these matters. you just take off all the stuff, plug up the places left open (intake manifold, carbs, mainly), plug up the exhaust port air injection ports in the head, figure a way to add a pcv valve, and that's it. There's things inside the carbs too, you could install early type throttle discs (this should be considered NOW so you don't do the same work twice-- in fact, you should probably think about getting a approx 67 set of carbs to rebuild because the 69 ones have various smog things that you really don't want- see below). The more proper way is to change things from the head gasket up. Get a head with no exhaust port air injection ports, get a 67 style intake manifold, 67 style carbs, get rid of the tall nut at the back of the head that supported the air injection rail, and other such details. The distributor is different too. Some people might want to consider some kinds of mods at this time, such as an aluminum stock style head, or other things. You probably want to learn all about all these options before you decide.
67 distributor is number 40897 (has advance curve and vacuum unit to suit pre-smog set up).
67 carbs are AUD 135F and AUD 135R, these have solid throttle discs, solidly mounted needles, no restriction on jet adjustment, no ports in carb body side, etc.
the problem with stock 69 carbs for smog is that the combination of features makes them hard to work on and prone to issues. The primary problems are caused by the spring loaded needle. In the normal world of SU this is just utter idiocy. An SU carb properly set up requires that the main jet needle be properly centered. A solid mounted needle, properly centered, does not ever touch the jet orifice. If it is not centered, the needle touches the jet opening, and causes friction and the piston cannot rise and fall properly. I don't know for sure, but over the years I have come to believe that some of the changes that were made in these cars were done because the manufacturers, in attempting to comply with US regulations, decided that people were not going to properly take care of things and made engineering adjustments accordingly. Thus the spring loaded needles, these are biased to one side, and constantly rub on the jet orifice, causing wear and friction. These are difficult to install and are not intended to be centered, centering is eliminated and this supposedly easy way results in horrible jet wear. The jet gets a groove worn in it and its orifice gets larger causing a richer and richer mixture. The throttle discs with poppet valves in them were (I think) an attempt to get rid of some tendency to backfire and also for the motor to run on (diesel) when shutting down-- the backfiring and tendency to run on, in a properly or slightly lean adjusted motor, are really a normal consequence of the high performance high compression setup and there is some debate as to whether modern gas is high enough octane to run properly on, but in my experience, with the '67 setup, properly adjusted, using 92 octane fuel, you will get a certain small amount of backfiring on down grades and if you are getting any dieseling, you need to slow the idle down and let the engine run at low idle speed for a short while before you shut down. If you are getting this situation you can richen your mixture a little bit and it will help. SU HS-4 carbs have a tendency to stick at a higher idle speed than they should and blipping the throttle to get the discs to go down to the low idle they should be at, can help-- but usually this condition indicates wear in the throttle shafts. Other fancier SU models have better throttle shaft sealing, and separate idle passages, so that you don't get this situation. But those carbs are on more expensive cars like Jags.
You may wish to discuss the carb/ smog situation with your mechanic because it is intimately connected with tuneups and carb setup/ repair. In other words you may not want to make repairs on stuff you are just going to take off.
Another thing to do SOON on your car if it has not already been done. In 68-70 or so they used an electric oil pressure gauge, which is not as reliable as what they had before 68. The sending unit is more expensive than the the whole gauge for 67 which gauge does water temperature too. In 70 or so they went back to an identical looking mechanically operated gauge- this is a reliable and what you want. The gauge goes right in the dash (vertical rectangular shape) and you have to run the solid metal piping from the gauge into the engine area and have a flex hose (as 67) to go to the engine. "
That's all of it I hope that helps you all.
scot
Thanks for posting that scot,interesting read and a lot of good stuff there.
Also thanks bob,I'll certainly keep that in mind.
Scot,
Will dig a set of carbs out tomorrow and send you a picture of the, PM me with you email address. I never have figured out how to post any pictures here.
Hey Bob, hope to get over to the auction at Tony's. If we are in town and the Wife is not singing somewhere then I plan to be there. Its just about a hour drive for me.
Marv
Just to update you all on the carb conversation. I had a nice talk with Joe Curto in NY and he understands the difference between the 67 and 69 carbs but really doesn't think that it's worth switching out if I already have carbs on the car. He can convert to solid needles but he believes that it's splitting hairs at that point. Get rid of the pcv valve and get the stock carbs running well and leave them alone. That is what Joe has to say on that.
For what it's worth...
