Looking for a strange thing
jlaird
Some kind of a brass coupling that goes to the carb for the vacume advance. I have the other end and the 1/8 inch copper line but know not what the fitting on the carb is or looks like? This would me a male peice that actually goes int the carb throttle body and somehow hooks to the 1/8 inch line.
Jack it could be a union fitting.Is the end you have a female nut/olive or flare?
I'm not sure you can get union parts,I think they come complete.And to be absolutely useless,I haven't a clue where you'd get such a thing. /ubbthreads/images/graemlins/rolleyes.gif
Stuart. /ubbthreads/images/graemlins/cheers.gif
FWIW, if the connection shown in the pic is like yours then it is also on TRs of the same era, possibly many other SUs -- so you might widen your search.
I cannot recall for sure if the line had an olive on the end or just a flare... though I am thinking it was flared. As noted, the connector itself is just a really small compression fitting.
If originality is not the issue, one could thread into the carb body a bit of small brass tubing, the couple it and the line with a short length of rubber tubing (I think that is more or less how Stromberg carbs make this connection).
jack are you sure its not one of the fuel line fittings? VB catalog page 84?
Noop, that's it in the Pic. The other end has a rubber L shaped fitting that the copper tube just slipes into.
Is that not a strange fitting and it even goes in the front carb. Bet that's going to be a bear to find. Hmm, maybe the folks that rebuild carbs. Will try them.
Hap where are you??
Guess I will check in Tonys store house next week as well, I hope.
""""Noop, that's it in the Pic. """""
Is this an SU ? most of them have a pressed in tube about .150" od. for ported vacuum take of.
If your carb body is threaded then measure the id of the hole as a start. Do you have a thread pitch guage that is narro enough to go in the hole?
Are you striving for originality? If not, epoxy a tube in the carb body...the thread will probably something goofy.
Guess I will go to my favorate parts house and see if I can find something to fit it and will get two.
[ QUOTE ]
I believe that Hap's on vacation this week.
[/ QUOTE ]
Hap is at the SCCA Runoffs in Topeka, KS this week supporting Ron Bartell's H Production Spridget. He'll likely return to the board when he gets home early next week.
Tim
