G
Well, I have turned to the dark side. I am abandoning my beloved 13-blade fan for good and installing a 16" Permacool electric fan. I know, I know, in past posts I have berated the use of an electric fan but now things have (or will) change. Since I am raising my compression and have to deal with headers, the stop and go driving in town will take it's toll on my water temperature. My problem is, because I am installing a puller fan (and replacing the hub with a machined disc) I want a place to insert my temperature probe so that I can work automatic as well as use a manual override. The wiring is not the issue. I will just follow Dan Masters' diagram. But I refuse to insert a probe in between the radiator fins. How about this one?: there is a little known and rarely used coolant plug on the right rear of the engine block. What a great place to insert a threaded temp probe! Just gotta figure out what the temp of the coolant will or should be in this area of the jacket and get the appropriate probe. Make sense. Does anyone out there see why this would not work. My other options are tee into the right side of the thermostat housing and run a probe with an appropriate pipe tee with a threaded probe or put a pipe tee inline with the top radiator hose (more room for leaks) or have the radiator shop braze in a fitting into a longer necked radiator inlet pipe from the same top hose. I plan to suitable wires, relay and fuse and have the thing mounted on the dash with indicator light (like I did my overdrive). Any wrong thinking here?
Bill
Bill
