Randall Initially thought it was the gearbox front seal since there was oil along the gearbox, dropping off the drain plug. And the gearbox was low. So, filled the gearbox, made sure the drain plug was not leaking and plugged the breather hole at the front of the gearbox, figuring that would be where the oil was coming from if it were the front seal. The car is not being driven but still got oil on the front of the gearbox so I figured it had to be residual oil draining through the rear seal from the last time it was driven. Just seemed like a long time for a drain down.
Am now wiping off the front of the gearbox daily hoping at some point there will no longer be oil, concluding drain down is complete. If that occurs, will start the engine to circulate oil and see if the leak re-starts. Hopefully, thereby proving its the rear seal. Or not (hopefully, that is) since that is not a good thing.
There isn't any oil at the top of the engine so don't think it would be the head plug or valve cover. Also, without the car being driven don't think it would be the draft tube or the fuel pump gasket. The hunt goes on.
