[ QUOTE ]
[ QUOTE ]
I discovered I had no signals or brake lights. I still have head lights and tail lights. Are these all interconnected? Does this sound like a short or a fuse? Where should I start?
[/ QUOTE ]
Check the "other" fuse--the one that does everything except for the horns. If it's blown the next challenge is to find out where is the short that made it blow. Good luck.
[/ QUOTE ]
Yup,
It would be the bottom of the two fuses on the fuse block mounted on the engine side of the firewall. It supplies stop lights, turn lights, gas gage, wipers, & heater fan. It may have blown from old age or as Michael says, more serious problems. If you don't have the 35 amp British fuse a 20 amp USA fuse will do fine. There are "supposed" to be a couple of spares, sticking end out,in holes in the fuse block. Thoughtful touch - Eh?
