Bill Young
Reference the 3 position lighting switch on the Sprite Mk II. It looks to have a resistor connected between terminal "1" and "2" for the purpose of dimming the turn indicator lamp connected to terminal "P' on the flasher when the switch is on. The connection drawing shows that this resistor is bypassed in the "off" position, allowing the turn indicator lamp to be full brilliance. My question is .. does this switch also bypass the resistor in the "side" position (parking lamps) or only in the "headlights" position?
