Ok, so my headlights stoped working some time ago and now I'm finally trying to figure out why. I discovered that one sealed beam was shot, so I went ahead and bought two new units thinking that might be the problem. Nope - even with two new sealed beams I still have no headlights. Now what is really strange is, when I unplug both headlights from the plugs, and measure the voltage at the plug, it seems to be working fine on both sides. I get 12v between black and the Blue/red with low beams and 12v between black and blue/white on high (might be the other way round, but the point is, it seems to change when I hit high-low beams. BUT - when I plug in EITHER or both of the sealed beams (new remember), not only do the lights NOT work, but the high beam light on the speedo stays on regardless of whether I have high or low selected. This sounds like a short somewhere - but where? I am heading back out to continue trouble shooting this odd problem. Going to pull the switch (its new also) on the steering column and make sure noting funny is hapenning there. Wish me luck and if you have nay ideas, please post them.
Cheers,
Cheers,
