sp53 said:
I see how I can get two valves close on the same piston, but not two valves open?
This is known as the overlap period, which occurs between the intake and exhaust strokes. All automotive cams have some overlap (some more than others). With the stock TR2/3 cam, the exhaust valves stays open until 15 degrees after the end of the exhaust stroke (BDC), while the intake starts opening 15 degrees before the end of the stroke. So there is 30 degrees where both valves are at least partially open.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]This all happens after I set everything once with the Haynes manual at 10. How could there be more room? When set at 10 correctly would that not be the maximum as the lob rotates? [/QUOTE]
Theoretically, yes. But as the old saying goes, the difference between theory and practice is that in theory, they are the same. In practice, they aren't.
In other words, your camshaft is either worn somewhat oddly, bent, or was not cut exactly right to begin with. But .002" isn't really enough to worry about, it just doesn't make all that much difference.
Note that the gap also changes as the engine warms up (or cools down). This is expected (and is the main reason for having a gap to begin with).
