nissanite
Hello All,
This is just a story about my journey.
I am building a no compromise TR4 engine with 91mm bore & fuel injection. I know!
This is about camshaft & lifters. I ordered a cam & lifter set from vender#1. Decided to get a cam from accross the pond that would work better in an injected motor, vender#2. After installation & 30 min on the dyno, found the lifters not rotating in the bores. My engine builder stated this was imperative. The lifters already had formed a wear pattern & it was suggested they would fail. After other conversations with forums & engine builders everyone had a different opinion. I ordered lifters from vender#3 who agreed in the rotating theory.
Upon inspection these lifters had a slight dome on the surface (recomemended). These were installed & found they would rotate to a position, then stop. Further inspection found they had high & low spots on the surface. They would rotate to the low spot then stop, duplicting the first problem.
We had the cam ground again & had the new lifters surfaced properly & the now rotate without stopping. This shoud allow them to wear evenly & have a long life.
If you know of someone or are building a new engine I highly recommend that you mark the edge of the lifters, install with the cam & rotate before you assemble the rocker shaft. It may save you $$$$ & alot of greif.
My engine is going back together this week & should be on the dyno by the end of the month.
