Alot of good advice has been given about lubes and first time starting procedures, so I won't talk about that, what I will talk about is lifter and cam quality. The solid lifters and cams we run in our cars need to be hardened and of the best quailty, one of the most common failures we see in our solid lifter engines are lifter and cam failure, most of the time, not that long after a engine is rebuilt. Regrinding your stock cam core or buying reground stock cam core is only a option if the cam has been properly hardened after it has been reground, many on the market are NOT. The most common used hardening procedure for a reground cam is nitriting, nitriting is surface hardening procedure that penetrates the surface aprox. .030", do not let anyone tell you Parkerizing is a acceptable hardening procedure, it is not, of course buying a billet cam is always the best way to go, but if a used reground cam core is nitrited after grinding I can tell firsthand you after years of using such units in race engines this is more than acceptable. Now on to lifters, I tested of bunch of lifters for A-series and MGB engine (A-series and MGB short lifter are one in the same) a few years back. I tested the Isky copy chilled iron lifters, Mini Spares lighten lifters and APT CF-04 lifters and stock replacment lifter, what I was looking for was a Rockewell C rating of mid 50s or higher, this is what we need to insure long lifter life in our engines, and the stock factory lifters were of this quality, the stock repalcement lifter was the only one of the bunch that failed the test, and it did so horribly, at Rockwell C ratings of 45-47, the APT, Chilled iron Isky type and MS lightend lifters all came in at 56 Rockwell C or higher, with APT CF-O4 lifter winning with a Rockwell C rating of 61. In all the engines I build I only used either reground nitrited cams or new billit cams, on the street engines I use APT cams, on the MGBs, David Anton can not get a reilable source of used cam cores on a constant basis, so I go with new billets, on A-series engines, he can get reliable cores from the A+ engine from the UK, which are nitrited after being reground and require switching to the later slot drive oil pump which will work in any of the A-series engines, then I also use his APT CF-04 lifters. This is not the cheapest approach, but if a cheap cam and/or lifters fail because you took the low road, then this path is by far the cheapest route.
