John_Mc
I recently refurbished the front suspension on my TR6 with all new rubber bushings (urethane on anti-sway bar) and new ball joints and trunnions. I did notice some immediate improvement, but not on the scale I hoped and I suspect it's because I have done nothing to the rear suspension. I still get a lot of rattle noise from the rear and even some "sliding" sensation over bumpy sections of the road. I'm sure the rear suspension needs work since in the 5 years and 21,000 miles (450 over the weekend!) I've owned and driven the car, I personally have done nothing to the rear suspension (except replace the right side shock-to-trailing-arm link. I should check my service records to see if the rear shock oil was checked when other service was done.). As I said, I'd like to tackle the rear suspension, but I'm not sure how much time I'll need and so I'm thinking I should just wait until the summer/fall driving season is over. In the meantime, I'm thinking that I should check the lever shocks to make sure they are functioning to the best of their capacity. So my questions are:
1) How do I check shock oil level/function?
2) If oil is needed what kind do I add for optimal performance? I recall reading posts about adding different viscosities of motorcycle shock oil to improve handling
3) For a first timer, how much down time would I be looking at to refurbish the rear suspension? (new bushings)
and finally
4) How beneficial would a rear anti-sway bar be?
This is a load of remedial questioning, I know. Thanks in advance for any advice.
and finally
