Spitfire leaning Spit
tomkatb
My 1977 Spitfire has always sat lower on the drivers side than the passenger side.
I changed the spring about 6,000, miles ago and that did nothing.
Yesterday I replaced the bushings in the radius rods. No help.
Is there any solution. Would new shocks help?
Larry
Which corner is lower? Which spring did you replace?
Remember when checking ride height to measure all four corners.
When one corner goes up, opposite corner goes down. Might have a spring problem on the other corner.
Shocks won't help, as they don't "suspend" the car. Some folks use air shocks to "fix" the problem; I consider that yet another band-aid fix. As Ron suggests, you need to look at the front suspension as well as the rear.
What spring did you use to replace the old one? "Stock" or "heavy-duty"? I've long had the theory that the ever-heavier "Federal" Spitfires -- with the rear frame extensions and heavier bumpers and overriders -- were often just too much for the stock spring. I've no conclusive evidence to prove my theory, except that I've seldom seen this classic "sag" on MkIV Spitfires with the same swing-spring (albeit with the shorter rear axles), nor have I seen much of it on early 1500s.
I used a stock spring from Moss or Victoria British.
As the bushings look good in the back perhaps the spring is the issue. Or my heavy self on one side.
Larry
Mine sat 1" high on the right side. I swapped the front springs/shocks side for side, and the difference became 1/2".
I have also tried biasing the rear spring by stuffing some rolled-up inner tube between the leaves on one side. This didn't work as well as I thought it might.
Maybe I have a twisted frame?
You could get the Spax adjustable perch shocks, but you'd just be masking the problem. (You would probably wind up with more weight on two diagonal wheels...plus they are coraaaazy expensive!)
Anybody know which air shocks that fit?
I sort of need shocks anyway. This is a shadetree fix, but I know nothing better.
Larry
Larry
I installed the Monroe MA-785 (for corvette) air shocks.
You need to cut the steel sleeves that come with the shocks, and I had to reuse some of the rubber from the old shocks. It's not a hard swap.
Also, to correct lean, you need to buy extra fittings for the air shocks to separate the two sides.
In my case(a 1980 Spit)i replaced the spring with a new Moss spring($265)& installed Monroe air shocks with independent split schraders & my problem went away.With the 2 schraders i can independently adjust the pressure in each shock. 25# on the left & 30# on the right.
Ken&Whitelightning
PS;If your running stock springs on the front you can also fiddle with the tire pressure in the right front for some compensation at the left rear.
