The other day I walked into the garage to find a big puddle of dark, thick oil under my left front tire and bumper bracket. The bottom of the idler arm is soaked so I'm assuming a seal has gone bad in the steering box somewhere. Anyone have any experience with this situation? The picture in the manual show the grill removed and the whole steering structure being removed through the grill opening. I'm hoping that's not the only solution......
Thanks,
John Noblin
'65 BJ8 owned since '69
Jackson, MS
Thanks,
John Noblin
Jackson, MS
You can drain the box, remove the cross rod from the steering arm and then remove the steering arm from the drop shaft. now you can extract the old seal and install a
