Nelson
Yesterday we pulled the engine on my 948 Sprite because of an oil leak that we suspected came from my new five speed. It turned out that the transmission was not the culprit. We found this out after we repaired what looked to be the cause but when we started the engine after reinstalling it the leak was still there. Today the engine came out again. We can see the oil has come out at the oil pump and run down from there. The pump itself appears to be ok but why is oil running down from it? There is a small crescent cutout on the bottom of the pump and a small hole into the block at that point. It was manufactured there and we can't figure out what its purpose is or if that is the source of the leak why oil didn't pour out of it when I had the engine running in the past. I made a new thicker gasket and we put a thin layer of RTV on it that is setting up now. My buddy thinks that perhaps the leak is due to an improper gasket seal but I am dubious. Any thoughts would be greatly appreciated. Pulling the engine twice in two days already was not my idea of fun. Having to do it a third time would be way more than I can imagine.
Hi Guest!
