I have heard of a procedure in which you put some sort of dye in your oil and then after running the motor for a while, you use a black light under the car to figure out where leaks are happening. Has anyone ever tried this, and do you know what the dye is called? I have a leak in my Spitfire that the source is hard to pin down and I though this might help, but I have no experience with it.
