dklawson
As before, this topic is related to problems I'm having with the Mini but I know there's more A-series engine advice here so I'm hoping the Spridget owners can help.
Last week after my car acted up I started a thread on this and a couple of other message boards asking what the symptoms of stuck valves are. Most the replies indicated that I lacked some key symptoms of a stuck valve. However, several people encouraged me to perform a compression or leak-down test. My car has decided it doesn't want to run anymore so I was moved to perform the leak-down test today. I'm looking for input from any of you who have done these tests to tell me if my numbers sound good or not.
I'm using a home-made leak-down tester based on the more-or-less common design of a pressure regulator with one output gauge, a pipe nipple with a 0.040" (1mm) hole/orifice in its bore, followed by a second pressure gauge that connects through a flexible hose to a spark plug adapter.
Each cylinder was tested the same way and each gave the same result. With the engine cold, the piston was brought to TDC so both valves were closed on that cylinder. The car was placed in gear so the engine couldn't turn. Air was supplied to the regulator and the regulator's output adjusted to 100 psi. There was leakage as expected, but each cylinder held the output pressure (downstream) at 85 psi. For each cylinder the leakage could not be heard in the carbs, nor in the exhaust, they were not leaking into the adjacent cylinder, nor were they producing bubbles in the coolant. In each case the leakage could only be heard coming up the pushrod tubes. This indicates to me that all my leakage was through the piston rings. I don't think it's leaking into the oilways but if it were... how would I know?
I was looking for leakage through valves that wouldn't seat but didn't find any. Now I'm curious though. What I've got appears to be 15% leakage around the rings. The engine has very low mileage on its rebuild and I'm assuming everything is OK based on the leak-down tests but I'd like to know what are "good" numbers and what are considered "bad". If I have a problem with the head gasket such that the pressure is going into the oilways... how would I know? Thanks for the input.
