I just got a digital volt/ohm meter - but it needs help. Turn it on, screen remains blank, except for a random line or dot on the right side when I press on the screen itself.
Sounds like a bad connection, right?
But take a look at the innards. First photo shows top of circuit board with the line of contacts for the screen. Above that is the flexible "connector" that goes between contacts and screen. Above that is the screen (face down). I assume it's an LCD screen. Board contacts touch the flexible connector, which touches the bottom of the screen.
There's no ribbon cable, or solid connection between circuit board and screen. How the heck do the signals get to the screen to control the display? I've cleaned off the board contacts, the edges of that rubbery connector, and the screen itself, with alcohol. No change.
Assembly is: display goes in window of case, then flexible connector at bottom of display, then circuit board is flipped over and placed so the line of contacts touches the flexible connector. Seems pretty inaccurate - but that's the way it was when I opened the case.
Second photo shows same layout, but display screen is flipped to show the face which should display the characters.
LCD panels don't usually fail - it's more likely to be a connection issue.
How on earth does that system work, if there's no ribbon cable?
And of course ... does anyone have a suggestion on getting it to work?
Thanks.
Tom
Thanks.
Tom
