twigworker
Someone has delivered a steering box/column to me for an overhaul. The problem is that all of the parts were loose in a corrugated box.:sorrow: I have everything ready to go back together but I am puzzled by one thing.
There are several slightly cupped shims, actually six, that have nearly the same ID as the OD of the sector shaft and I am not sure where to use them. I think that they go over the shaft before it is inserted into the box to provide a good working surface between the two when pressure is applied by the external adjusting screw.
The “factory” schematic of the box in the Bentley manual shows only the earlier box that does not have the roller style peg and no shims.
Does anyone know of a drawing of the parts for the later cars, or can someone answer my question about where these shims go and how they are supposed to be oriented?
Thanks in advance. Jack
