Kerry, if you have an upholstered occaisional seat to install you need two threaded "bolts" which go into the ledge behind the front seats.
These are not normal bolts, but have hex shanks above the threads, a thinner "neck" about .75 inch above the ledge and a rounded head. The seat cushion pops into position and is located by these pins. I forget whether a captive nut is on the underside of the ledge but I suppose you could tack weld one in place if your car did not have this option originally.
I should point out, my TR4a donor shell came with this arrangement but no interior whatsoever, so I am speculating that this is how all this works, not 100% certainty!
Hope this helps, Simon.
