I just got a '79 MGB LE, all is pretty good with the car except for some of the electronics.
I am working on getting a manual, but haven't yet, I am pretty familiar with british cars, but everything I have had has had 60s or 50s era Lucas wiring, the late '70s cars have a LOT more stuff going on.
Anyway,I have some issues I am trying to sort out, any ideas on likely problems (or better even yet solutions!) appreciated.
Gas guage does't work, new sending unit didn't help, everything seems to be hooked up OK.
Temp Guage doesn't work, everything seems to be hooked up OK, any way to test the sensor?
Back up light no work, new switch on tranny (I didn't install it the previous owner did) I get power back there, but the power doesn't seem to be enough to light the lights, lights light when hooked up to good power elsewhere, 12 volts at rear lights until I hook up the 2nd back-up light, then it drops to about 3 volts, weird.
Any suggestions of likely culprits or good tests appreciated, I have a multi-meter and know enough of how to use it to be dangerous.
P.S. Hazard lights don't work, plug is not hooked up under Dash, and back half of switch appears to be missing, pretty low on my list of concerns, mostly mentioning it in case that might affect the rest.
Thanks, Greg
Thanks, Greg
