Thanks again Andy. You may have saved me quite a headache. As I should know, one cannot do enough research on these cars before any modification is made.
You are correct. 68-74 units are 1280 TPM while 741/2-80 units are 1000 TPM. A mixed combination would make for a huge speedo error - over 20% - too low.
Thanks to you astute advise, I contacted the supplier of the transmission and he is removing the 1000 TMP drive gear and replacing it with a 1280 TPM gear.
Hopefully this will solve the problem.
Thanks again
[ 03-06-2004: Message edited by: One Fast MGB ]</p>
