SMGoose
When I first got my TR4 a couple months back, it grinded into 2nd and 3rd. I immediately changed the gearbox fluid; it needed it pretty bad and some metal shavings clunked into the drain pan. With the hypoid gear oil, it shifted better but still had problems downshifting into 2nd.
Now, while settling my misfiring issue, something must have jarred loose in there. I heard a few loud bangs from under the car and now, at idle in neutral, there's a steady knocking that stops when I push in the clutch. Is it rebuild time? Bearing broken loose? I fear the worst here.
