Healey Nut
So I have been doing some preassembly of parts ready for the 62 project .
One project to tackle was the installation of new king pin bushings .
I had the swivel axles all prepared and sandblasted clean .
Fortunately for me I had two sets of new king pins and bushings in my parts box .
After destroying one upper bushing trying to install it I decided on a different approach .
I carefully measured the bores and bushings and decided the interference fits we’re just way too tight to work .
The new bushings are split because I think they are rolled from plates and the edges of the seam where they join are not exactly parallel and square to each other so I carefully used a hack saw and ran it through the joint in the seam of the bushing edges to make it slightly wider, but also to make the edges parallel and square to each other . It also allows the bushing to collapse in just a fraction more when inserted into the swivel axle .
Success. All bushings fitted nicely with no gap in the seam joint and just the right amount of interference to keep them in place. All that’s needed now is to take them to my friendly machine shop guys and have them use their expanding reamers to size them for the new kingpins
