MGB Just repaired horns on 72 MGB
Tim66
Member
This may be common knowledge but...If you want to keep your original horns and they don't work it is simple to repair them. Drill out the rivets holding the two halves together. You'll find a metal plate sandwiched between the halves. Under the plate is a set of points and inside the same lower half an electromagnet. Clean all the rust off of the plate and horn body halves. Clean the points with emery cloth. Then put it back together. I used RTV sealer to seal the halves and pop rivets to hold them together. The horns now work.
Tim
Great tip! You should put that in the Wiki Project.
Thanks Tony. I don't know anything about the Wiki project. Can you enlighten me?
Tim
Go to the Main Forums page & scroll down to Wiki Project....all the instructions are on it....it's our little private Wikipedia.
