Just installed a Weber
jbuffalo
I am quick- only took two+ weeks. Runs very well-fast-revs easy. Only one problem is the idle is high-tried to back down adjustment screws-still high-but better-maybe the idle mixture screw. This was a tough job-broken bolts-hard to get at items. The directions(as they are) say to plug the vacuum line(carb side) from the distributor--I have it hooked up to the carb-is this right? 1978 Mg midget 1500 weber 32/26 Dgv. thanks Jim
