RickB
So what can be done to make them fit right?
The center hole is fine but the thickness of the material (aluminum) makes my lug studs too short.
They are fine for the steel wheels but the backing around the lug holes is very thick.
Also the holes are not exactly centered over the lug studs, they are off by just a little. The lug stud isn't exactly in the center of each hole and also each hole is bigger than the stud so there is about a half inch diameter hole and what are the standard lug studs? 5/16"?
I think I've seen this discussed before, so thought I'd ask.
The holes could be drilled out or filled and re-drilled or what other possibilities? Longer lug studs I suppose?
