tony barnhill
Great Pumpkin - R.I.P
I needed a couple more jack stands today (only have 10!) so I dropped by Harbor Freight.....unitl 10th of next month, they have a pair of 3-ton jack stanss on sale for $11.11! Item #38846.
tony barnhill said:I needed a couple more jack stands today (only have 10!) so I dropped by Harbor Freight.....unitl 10th of next month, they have a pair of 3-ton jack stanss on sale for $11.11! Item #38846.
That's strange ... the 3 ton stands I have from HF are actually quite beefy and weigh a fair amount more than the 3-ton stands from another source. And I've had them loaded to over 2/3 rated capacity, with the front of my 25' motorhome; and no sign of problems. (Of course I know all too well that there are no signs of problems until they actually fail ... I keep a collapsed sheet metal stand hanging on the wall as a reminder.)IanF said:I have 3-ton stands that weigh 3x as much... which leads me to believe the H-F are made from the thinnest, cheapest steel they could find
TR3driverThat's strange ... the 3 ton stands I have from HF are actually quite beefy and weigh a fair amount more than the 3-ton stands from another source. [/quote said:Well, that just proves one of the other things I've said about H-F: look before buying. As you never really know what you're going to get until you hold it in your hands. I won't say that H-F isn't good for certain things (I have a tranny jack from them that works great for as often as I need it), but I wouldn't use their $12 3-ton stands to support my lawn tractor.
TR3driver is correct - HB had another larger set of 3T jacks that are way heavier than my big 3T Craftsman jacks (from just lifting them at the store, they feel heavier). I bought some more of the small $11.11/pair HB 3T jacks this morning & weighed one of them. They are also heavier than my small 3T Craftsman jacks (that are the same size as my small HB jacks)!TR3driver said:That's strange ... the 3 ton stands I have from HF are actually quite beefy and weigh a fair amount more than the 3-ton stands from another source.
tony barnhill said:I bought some more of the small $11.11/pair HB 3T jacks this morning & weighed one of them. They are also heavier than my small 3T Craftsman jacks (that are the same size as my small HB jacks)!
Well, considering I've used my small Craftsman jack stands for almost 10 years now without any problems, it attests to their strength. And if weight is the criteria & the HB jack stands are heavier, they should be moreso safe!IanF said:That's not saying much...
Hap Waldrop said:I also got the HF aluminum jack, the bigger one of the two,
