Hello All,
I have been putting off rebuilding the brake servo unit on my 67 BJ8 for the last year. Checking the engine oil level always included checking the brake fluid level and topping it off as needed. Fast stops would occasionally result in a smokey takeoff for the cars behind me. Well, this morning on the way to work, things got a lot worst and the servo cylinder is not holding pressure any longer. A firm push on the brake pedal goes to the floor and the people behind me can't see the car any longer. I disappear in a cloud of white smoke!
The slave cylinders at the wheels appear in good shape. The rear cylinders were replaced by the previous owner within the last 5 years. The front calipers have no leaks and don't seem to bind. The master cylinder isn't leaking.
I need to rebuild the clutch master cylinder to stop the small pressure leak on the carpet. I plan on doing the brake master cylinder as a preventative measure. I am also thinking about new pads, shoes, rotors, and drums to stop the brake pulsations.
Where is the good place to get all of these supplies? Is Moss a good choice? Assuming that I don't need to have anything re-sleeved, I wanted to get this job done this weekend so I will be ordering parts today.
What else am I missing here? Should I also rebuild the calipers? Any suggestions or tips?
Thanks,
Mark
Thanks,
Mark
Hi Guest!
