mrsprite
Here's another update. After getting everything back together and adjusting the valves, I noticed oil seeping from the oil pump (where the filter attaches to it). Evidently, the o-ring didn't seal very well, so I had to re-remove the oil pump and put in a new o-ring.
After replacing the o-ring I put the radiator in and filled it up and started her up again. This time, for some unknown reason, it decided to have a coolant leak.....where the timing cover mates to the block. I had to strip the front of the engine down once again to replace the gasket.
I get it all back together again and start it up (did not install radiator yet). What's that noise? I guess I never heard it before, but it had to have been making noises the last time I started it up......the water pump was going out! What next!? I ordered a new pump and installed it today. Finally, I think I have the engine finished. I re-installed the radiator and filled it up. I let it idle for several minutes and drove it around the block a few times too.
Tomorrow I put the hood on and figure out where to take it for an alignment. Then it's lots and lots of cleaning.....she's filthy! /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Here's the Datsun A15 in all her glory:
Here's a shot of my Bugeye without the hood:
Here's a shot of the frame rail that was cut to make room for the engine. This is the only thing on the chassis that was modified.....all other mods were done to the engine.
This one shows the bracket used to reconnect the cut rail.....the crank pulley is why this rail had to be cut.
Finally....this is the reason my Bugeye was down in the first place.
That's it for now......just thought I'd share. I hope to be driving my Bugeye on a regular basis starting this weekend! There's enough nice weather left to enjoy her before the snow flies (it was in the mid-80's today). Can't wait!
