It still haunts us to this day...
Steve_S
From an email my father sent me today:
A fellow on Miata.net forum was having start/stall problems with his 2001 Miata. Sometimes it wouldn't start at all, other times it would start and quickly stall, and other times it would be fine and run all day. VERY aggravating. Dealer couldn't find the problem. Ultimately, he traced the problem to the anti-theft immobilizer module (starting in 2001, Miatas come equipped with a "chip" in the key... if the immobilizer circuit in the car doesn't recognize the key, the car won't run properly). When he removed the immobilizer module and opened it up, he found some "tin whiskers" (very fine strands of solder) between a few of the pins. He used compressed air to blow clean the circuit board, reinstalled the immobilizer module, and all
is well (so far).
"Tin whiskers" are a known problem in manufacturing and assembly of circuit boards. And this fellow's story is well worth noting and committing to the back our minds for that day where we just might benefit from his troubleshooting experience. But there's a bit more to this fellows story....
When he had the immobilizer module out of the car, he took a few pictures. One picture alone explains everything! Have a look:
https://forum.miata.net/vb/attachment.php?attachmentid=63434
hehehehehe...Lucas has immobilized lots of cars over the years.
Great, one more thing to let the smoke out of. Now I will have to rethink the Miata purchase...
Can you even see tin whiskers? I saw something about this on History Channel (probably on <span style="font-style: italic">Modern Marvels</span>), and I thought they were microscopic?
-Wm.
Most here have probably seen this before - but one of the counter workers at the 'foreign auto parts' store that I used to frequent many years ago had a t-shirt with the slogan -
"LUCAS - Prince of Darkness"
I think that explains a lot!
Some our cars are probably equipped
with one of those.
If you look really hard,maybe
there's one hidden under the seat,
in the frame,etc.
They probably used some our
cars to perfect a defective part.
- Doug
You guys should see the outside of a Rolls-Royce Trent 800 series engine (found on the 777). Just about every component on it says Lucas Aeromotive.
I used to have one of those.
New Lucas advertising motos:
"Our Parts are Perfectly Defective!"
"Your Money back if it Works"
It's so OBVIOUS that J. Lucas & Sons has FINALLY found their niche!
