G
Bought this so far plus shoes and clutch master/slave from another source. Getting kinda excited but this isn't a keeper. Nice to finally have one after liking them for 30 years. ( o.k, this is the second one but I can drive it.) Probably will pop for new dash and door panels. Car alreadyy has new seats and carpet. Still looks like it was painted by Ray Charles with a stick.
Part # Description Qty Price Total Status
7-029 BRAKE CALIPER-LH-NEW 1 REQ 1 99.95 99.95 In Stock
7-030 BRAKE CALIPER-RH-NEW 1 REQ 1 99.95 99.95 In Stock
13-004 SEMI-METALLIC BRAKE PADS 1 19.95 19.95 In Stock
7-843 BRAKE HOSE-FRONT 2 REQ 2 9.95 19.90 In Stock
7-844 BRAKE HOSE-REAR-LH-CLUTCH HOSE 1 9.95 9.95 In Stock
7-842 BRAKE HOSE-REAR-RH 1 9.95 9.95 In Stock
7-953 WHEEL CYLINDER REAR-.70" 2 REQ 2 12.95 25.90 In Stock
7-7538 KIT-WHEEL CYLINDER RETAINING 1 14.95 14.95 In Stock
7-085 MASTER CYLINDER-BRAKE 1 99.95 99.95 In Stock
1-477 GASKET-VALVE COVER 1 3.95 3.95 In Stock
3-8067 FOLDING COUPLING ASSEMBLY A/R 2 16.95 33.90 In Stock
5-497 SHOCK LINK 2 REQ 1 24.95 24.95 In Stock
3-171 FILTER-AIR A/R 2 5.95 11.90 In Stock
12-942 GREASE CAP 2 REQ 1 7.95 7.95 In Stock
1-371 THRUST WASHER SET-STD 1 5.95 5.95 In Stock
14-783 SPLIT PIN A/R 2 0.45 0.90 In Stock
7-7539 KIT-RETURN SPRINGS 1 9.95 9.95 In Stock
