martx-5
Hopefully it never had DOT3 in it as DOT4 is for the British rubber seals and cups.
Actually, the only real significance between DOT3 and DOT4 fluids is the dry and wet boiling points, with the DOT4 having higher boiling points. It is not just for old British brake seals.
What you're thinking of is the days when there were different fluids for different British brake manufacturers. I seem to remember such designations as "Crimson" and "Amber" and "Green". Below is a quote from Moss about this very topic, followed by a link to the whole article which has a lot of good technical info in it.
Traditional Concerns for British Car Owners
In the good old days, dire warnings of problems caused by using the wrong brake fluid in a British car were common. Anyone reading a warning like "as the cups in the master cylinder are pure [natural] rubber; it is imperative to use only the recommended fluid. Any other fluid may be dangerous" would probably take it seriously. Such strong concerns were very valid in the 1950s, but much less so now, even for 1950's vintage cars. There are several reasons why we can be less worried about our hydraulic systems "turning to goo" if the wrong fluid is used:
1) Pure natural rubber hydraulic seals are no longer made for our cars
2) More than likely, the original natural rubber seals have been replaced.
3) Brake fluids meeting current standards are compatible with the virtually every type of seal available, including natural rubber
4) Brake fluids meeting current standards are safe to mix (although mixing them is not recommended)
And this brings us to the subject of this article – brake fluid.2) More than likely, the original natural rubber seals have been replaced.
Classification of Brake Fluids
Brake fluids are classified by their physical properties. The standards in the US come from the Department of Transportation, which is where the “DOT” in the brake fluid classification DOT 3, DOT4, DOT 5 and DOT 5.1 comes from. The standards are set forth in the Federal Motor Vehicle Safety Standards 116 (FMVSS 116). [26] The Society of Automotive Engineers (SAE) also has standards that apply. SAE Standard J1703 (DOT 3 Brake Fluids), J1704 (DOT 4 Borate Ester Brake Fluids), and J1705 (Low Water Tolerance Brake Fluids, or DOT 5 Silicone Based Fluids) are frequently cited in publications on brake fluid, along with the International Organization for Standardization (ISO) 4925 specification for “non-petroleum based brake fluids for hydraulic systems”. The DOT 3, 4, 5 and 5.1 brake fluids we will be discussing are all non-petroleum based brake fluids."
https://www.mossmotors.com/SiteGraphics/Pages/Brake_Fluid/brake_fluid_long.html
